3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Why doesn't my spline become a solid filled object?
2 REPLIES 2
2465 Views, 2 Replies
Hello, I'm trying to draw a heart, i made this spline and closed it at the origin (even the message "close spline?" And I said yes), however, when extruding, the internal part of the object is not filled, only this small thin part is extruded. internally it is "empty", what can it be?
without  extrude command, spline finishedwithout extrude command, spline finished
when i tried extrude command, the internal area not "filled"when i tried extrude command, the internal area not "filled"
Labels (2)
2 REPLIES 2
Perhaps you have overlapping vertices in your spline.
Add a normalize spline modifier with an edge length of 0.8 or something.
Thanks, it's works.
I'll try apply material on object now.
