3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
warning no file saved. You are rendering a scene with no assigned file.
6 REPLIES 6
14306 Views, 6 Replies
Good morning.
I have created a Kitchen scene in 3D Max but when I come to render it using either Vray or Mental Ray all I keep getting is:
'warning no file saved'
You are rendering a scene with no assigned file. Frames may be lost.
Continue yes or no?
So obviously I chose 'yes' then it goes through the rendering process showing nothing but a White screen - and it also 'loops' it continually repeats the render like it's stuck, I think they call it a batch or multiple renders but I only want one render as it's a still not an animation project.
I have been into Render set-up and tried saving it as different file types and renaming it but nothing seems to work.
Funny thing is I didn't have this problem a few days ago the same scene rendered just fine using Mental Ray and vray trial version  - so between then and now I've inadvertently broke something
I have deleted the two 'mr sky portals' the skylight and the 'physical camera' and replaced them back into the scene but to no avail.
Also in the Render Set-up properties I checked that there were no 'all white backgrounds' anywhere, including in the 'Environment' properties box as well.
Plus I have created a new scene in a completely new file and it rendered just fine using both Mental Ray and Vray, none of the 'no
file saved error appeared at all.
It's a YouTube kitchen tutorial that I've been following titled below, along with it's url and I hope I've attached the file in question correctly too.
Kind Regards.
Cad-Learner
3ds max Making of Kitchen (fast forward) https://www.youtube.com/watch?v=sSt2f2N8UKw
6 REPLIES 6
don_3259
hi dear friend the issue you have set animation segment in render menu click on single frame option then you not get that.
thanks
Autodesk Student Amassdor
Guest & Visiting Lecturer
Ali Sajjad
don_3259
thanks
Ali Sajjad
in reply to: don_3259
Thank you very much indeed for your swift reply re the 'render error' many thanks.
Have a great day
Cad-learner Haden Cush
Hi Ali I did what you suggested and selected single frame is illustrated and the error message did not appear so that's good - however when I tried to render it returned just a blank white screen again which is a pity.
I wonder what it could be?
thank you
Cad-learner
don_3259
hi dear friend check your materials carefully i have checked there is some problem with them as you are using vray check its render settings.
thanks
Ali Sajjad
I get the same problem with my rendering TT_TT. But I found your post. Thanks you so much Smiley Happy
