Viewport rotation sensitivity
How do I adjust the rotation speed of my viewport? I like very high cursor speed, but I hate how ridiculously fast the viewport rotates. Additionally, it messes with my gaming muscle memory. Is there a way to make the mouse sensitivity lower in the viewport?
ads_czechoj
The Mouse panel lets you customize mouse behavior.
Main Menu => Customize => Customize User Interface => Mouse tab
Alt + MMB is the issue.
miledrizk
There is no Max settings to control ALt+MMB speed,
There is a workaround, but maybe it's not very convenient for you, in case you don't like
To affect the mouse's speed everywhere, and that's to go to control panel, Mouse, and change
Globally the pointer speed of your Mouse.
miledrizk@gmail.com
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
I’ll just bind my mouse’s dpi shift to the alt key, that should do it.
I don't see this is as an option
krankes_etwas
hey hey,
this topic is pretty old but I'm still searching for a solution..., is there meanwhile a possibility to set this in max ?
Or maybe any config files or registry entrys where I can change it ?
My Mouse is working with 500 dpi/epdi wich is pretty low.... but in Max its just 3 cm to make 360 degree turn, thats not acceptable for me.
