I have a massive issue with my display settings and my Graphics card (Nvidia GTX 1070)
The problem arises when I am poly modelling and attempt to select any vertex/edge etc to modify it. As soon as I select 'vertex' or 'edge' etc the entire object disappears. It matters not if I am attempting to modify an editable poly, spline or mesh. I have checked various forums for possible solutions such as adaptive degradation, driver configuration within MAX and viewport setup. I have tried installing roll back drivers and playing with the display settings within the Nvidia control panel but nothing works. I thought it could be the model of my card being designed as a gaming card but apparently others are running this card with no problems.
Anyone got any ideas? I have attached a screencast showing what happens.
Thanx
Solved by miledrizk. Go to Solution.
Well you mentioned that you tried driver configuration, so probably you did what i'am about to ask you,
But did you try changing the display mode within 3DS Max to an older/legacy one?
Another thing, is this happening in all your files?
Did you try with a new max file on a simple box, for example?
Hi there,
Do you know what? I have been going over all the possible solutions to this issue the past couple of days....(this has been going on for a while now!) Changing the display driver was one of the first unsuccessful things I tried...Just tried it again and guess what!!!!!!! It worked....on new and old scenes.
Thanks for jogging my memory!!
Appreciate the feed back.
Glad it worked!
Have a nice day! 🙂
