3ds Max Modeling
Welcome to Autodeskā€™s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Showing results forĀ
Did you mean:Ā
UVW Map modifier - might be a simple problem but I am stuck
2 REPLIES 2
428 Views, 2 Replies
It might be a simple explanation (im not applying parameters right or maybe it is because i have multi-sub object material), but I don't know what else to try. I have applied Physical materials with Bitmaps as Base color map and Bump map. On the same object the same materials repeat several times. I use UVW Map modifier, applying it on the whole wall object on which the materials repeat several times. As you can see on the 5th floor, the same bitmap is applied on all red and all white areas, yet they all look completely different: on the left side the whites are good, the brick colored are a little too big, but on the right side they are striped and look horrible. I use U, V and W tile size 10, and x alignment as parameters on UVW Map. Any ideas what's wrong and if there is anything I could do?
I attach even the file with only the 5th floor.
Tags (2)
2 REPLIES 2
It looks like it has to do with choosing Box instead of Planar. Still, the materials look striped šŸ˜•
