- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello, I recently came across this problem.When I select multiple objects, for instance 2, and then I apply a Unwrap UVW modifier and then click "Open UV Editor", I can't seperate the UVS. According to a youtube tutorial from 3dtotal, the person says by selecting a certain face on any of the objects and then growing it, it should select all faces of the certain object, but leave the other object unselected. I'm using 3ds Max 2018 and apparently this method doesn't work.
