3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Texture problem
2 REPLIES 2
268 Views, 2 Replies
Texture problem
I created a model in AutoCAD and then loaded it into the 3dsmax, so the model is still linked.
The layers were also taken over in 3dmax. The problem is that if I want to assign a texture,
other parts get this texture as well. These do not have the same layer. I then tried to correct
it with the command "Edit mesh". But that did not help either.
Did someone already have this problem?
Tags (2)
2 REPLIES 2
They share the same material.
You need to give individual parts different materials.
eighter detach a part with editable poly and give it a different material, or make a Multi-Sub Object material and use material ID's.
Many thanks for your response. I could finally solve the problem. I do not know exactly where the
problem is. I suspect it is due to the link with the AutoCAD.
Technology Administrators
