3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Smoothing solution for modelled sphere
3 REPLIES 3
projinf3d
331 Views, 3 Replies
I have this modelled sphere with highly visible polys/quads .. I've tried adding auto-smooth, under the Edit-Poly stack.. I have welded all vertices & even attempted Turbo/Mesh Smooth.. nothing works!?.. any ideas anyone?...
Tags (2)
3 REPLIES 3
- some parts of mesh have explicit normals
- mesh has different IDs with multisub material applied
Can you please recommend a way to remove such explicit normals?.
Assuming once removed, would be somewhat a work around??..
If my guess is correct, this should help:
- apply EditNormals modifier
- select all normals and press Reset
