Hi.
When I link a FBX file from a revit model (with combine by Revit category)
I can´t rotate the whole model as it was a group, it rotates in diferent directions
I need to rotate the whole model to place it correctly.
Thanks!
Solved by Fadhil_Farook. Go to Solution.
Currently you rotate tool is set to rotate about the object's pivot points. Meaning, if each object has a pivot point facing different directions, those objects will rotate independently from the rest about their pivot points.
What you have to do is change from object pivot point, to center of the objects' selection.
Also check if each model's pivot point is facing the same direction so that if you use rotate about object's pivot point, the all rotate in the right direction while remaining in the same position
