3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Rock Faced Block?
1 REPLY 1
jpiepenburg
215 Views, 1 Reply
Rock Faced Block?
I would for a stone company and we use 3ds Max with V-ray for all of our renderings.  One of our challenges is getting a believable realistic rock face texture on a block wall with sharp corners at the joints. Like this...Rock Face 2.jpg
Please dis regard the numbers.
We have tried multiple approaches with limited success.  I am hoping some of you may have a good and easy solution.
Thank you!
1 REPLY 1
What approaches did you try already?
I think it would be much easier to make textures in external software like substance designer, quixel mixer etc.
If nothing except max is available, I would try to start by soft-selecting "front" vertices of dense mesh and applying noise with tiny value on X, Y and more on Z. Z here is frontal surface direction/normal.
Then displace it by some stone/noise/dirt/grunge texture from the web, maybe in few iterations using different textures.
Assuming combining a bunch of maps baked from resulting mesh in photoshop for diffuse is also not an option, I would try to make some sort of composite material with those maps as masks to blend several noisy patterns.
Would be a good reason to finally learn how to use DataChannel. Seems like it might help in this case, but atm it looks scary and alien to me =(
