Good afternoon
I have a floor plan dwg file that doesnt want to align to the z axis on the perspective plane origin point, i have moved it to x:0 Y:0 Z:0, but the floor plane is still far off the z origin point. I have moved the pivot to center of object e.t.c and it is still off. I also tried snapping it to a new "dummy object" which is aligned perfectly on the origin point (z:0 y:0 z:0) which worked, but on the floor plan the z: co-ordinates are way off (even though it is aligned to a perfect object).
Please will someone help if you know what is wrong
Solved by RobH2. Go to Solution.
That sounds odd. Have you tried a "Reset Xform" from the Utilities Panel on it?
Can you upload the file? Maybe just the floorplan if necessary.
Rob Holmes
