3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
proplem with modeling
2 REPLIES 2
487 Views, 2 Replies
my proplem is that when i try to add an image to my plane the image is imported in a small shape and reppeted next to each other i can't really explain it but in general when i import an image it dosen't show up as it should
2 REPLIES 2
kgokhangurbuz
Hi;
This is because of "Real World Map Size" Option. You can solve this in 3 ways;
-Un-tick "Real-World Map Size option under the "Plane" that is created.
-Or go to the related materials map, un-tick "Use Real-World Scale" option.
-Or apply related object a UVW Map Modifier from the Modifier List rollout from the Modify panel and un-tick "Real-World Map Size" option.
Best Regards;
look into the maps options and uncheck the Tile checkbox there so it won't tile. then look to where it says place image click view and you can resize the image there. click apply
