my proplem is that when i try to add an image to my plane the image is imported in a small shape and reppeted next to each other i can't really explain it but in general when i import an image it dosen't show up as it should
Solved by kgokhangurbuz. Go to Solution.
Hi;
This is because of "Real World Map Size" Option. You can solve this in 3 ways;
-Un-tick "Real-World Map Size option under the "Plane" that is created.
-Or go to the related materials map, un-tick "Use Real-World Scale" option.
-Or apply related object a UVW Map Modifier from the Modifier List rollout from the Modify panel and un-tick "Real-World Map Size" option.
Best Regards;
