I have a question about the properties of light(option roll out and sampling). I remember in the previous version of 3ds max when I create several lights they have the same options and sampling. But in a new version (3ds max 2017) these properties discard every time when I create a new light even in sequence. Is there any settings for this problem?
Thanks.
Thanks.
Solved by Alfred.DeFlaminis. Go to Solution.
Hello @Anonymous and welcome to the community,
I must be testing on the wrong lights, would you please help me to reproduce this with some steps please? I was trying the mr Area Spot but in both versions it didn't remember the sampling for certain areas. Is this a specific type of light that you are using? Thanks for any additional information.
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
Best Regards,
Hello @Anonymous,
Thanks for the extra information. With Max lights this is working for me, but I can confirm that with Vray I am not getting the settings saved when I create new lights, although I do remember that I used to. I checked in 2016 and 2017 to make sure it wasn't a Max version issue, same result. I"m sure they're working on it. When I cloned/instanced the lights however they kept the same settings, might be a useful workaround. Happy Holidays!
Best Regards,
Hello @Anonymous,
Best Regards,
Hi did you ever find the answer to this question? I have been searching for hours and this is the first time I found anyone with this same problem. I like to create multiple lights using the AutoGrid to place them in the correct location and really need V-ray to retain previous light settings.
Thanks!!
Thanks!!
