I'm trying to follow this tutorial where a plane is divided into equal segments using connect as shown as below
but when I try to do the same, the edges are not created the way they're supposed to. They're too far away and not divided in equal distance
Wireframe
Did you cleanly model from a simple box primitive without segments?. Did you delete the edges afterwards? Because it looks like the edges are segmented. Like in the picture i posted. So there are still vertices but without the edges. You can delete them using backspace. Perhaps post an image in vertex mode.
