3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Problem with Connect edges
2 REPLIES 2
553 Views, 2 Replies
I'm trying to follow this tutorial where a plane is divided into equal segments using connect as shown as below
but when I try to do the same, the edges are not created the way they're supposed to. They're too far away and not divided in equal distance
Wireframe
2 REPLIES 2
Did you cleanly model from a simple box primitive without segments?. Did you delete the edges afterwards? Because it looks like the edges are segmented. Like in the picture i posted. So there are still vertices but without the edges. You can delete them using backspace. Perhaps post an image in vertex mode.
You're right. I went to vertex mode and found out the vertices were still there without the edges. I deleted them and was finally able to do what I wanted. Thank you so much!
