3ds Max Modeling
Welcome to Autodeskโ€™s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
path deform problem
2 REPLIES 2
5145 Views, 2 Replies
path deform problem
the chain follows the path by adding path deform modifier but at the corner there, it changed the size of the chain. May I know how can I solve this problem? thank you ๐Ÿ™‚
2 REPLIES 2
This generally occurs when you modify the spline which is being used for the PathDeform, or you haven't xform both the Spline and the Object before adding the PathDeform modifier.
Check this thread: http://forums.autodesk.com/t5/Modeling/Best-way-to-create-wire/td-p/5109010
yea, it works perfectly now after i redo with the method provided in that link. thanks a lot!
