the chain follows the path by adding path deform modifier but at the corner there, it changed the size of the chain. May I know how can I solve this problem? thank you ๐
This generally occurs when you modify the spline which is being used for the PathDeform, or you haven't xform both the Spline and the Object before adding the PathDeform modifier.
Check this thread: http://forums.autodesk.com/t5/Modeling/Best-way-to-create-wire/td-p/5109010
@blakestone wrote:This generally occurs when you modify the spline which is being used for the PathDeform, or you haven't xform both the Spline and the Object before adding the PathDeform modifier.
yea, it works perfectly now after i redo with the method provided in that link. thanks a lot!
