Hi.
I have an animation of sprayed concrete on a wall (using PF Source). I wanted to turn the first pass into a solid (mesh or poly) so that I then have only one particle system for the second pass (to ease rendering).
I have used the Mesher Compound object to turn particles from a PF Source into an Editable poly. When I render, the poly object only seems to have picked up a certain amount of the particles (see attached). The LHS of the image shows the particles and the RHS shows the Editable poly of the particles.
I expected to see "like for like" but it looks like the conversion loses part of the PF Source particles.
Can this be achieved or are there limitations with this process?
T
