Hi guys, I've issue with OpenSubdiv in 3D Max 2017... hard corners get something like dent or deformation... I tried to make the corner vertex with 4 edges instead of 5 edges but I still have the same problem ... ( screenshots attached one for OpenSubdiv active and the other with it inactive) ... also, I attached the scene for more clarity.
Thanks.
Solved by RGhost77. Go to Solution.
You have double edge in this region of model because some verts not welded.
woow, nice catch.... although I always take care of isolated vertices and double edges and all these issue, I didn't catch this one even with XView. Too much thanks, appreciated.
