3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Not able to move the object
4 REPLIES 4
534 Views, 4 Replies
Hello I was using 3ds max for light and rigging but all of a sudden I am not able to rotate or move the grid using alt+scroll and scroll just for moving. However I am able to zoom in and zoom out with the help of scroll button but for the above mentioned they are not working. Please help me .
4 REPLIES 4
miledrizk
Go to customize menu, Preferences, Interaction Mode tab,
Set it to 3DS Max and press OK. Hope this will solve it.
miledrizk@gmail.com
3DS Max 2021, V-Ray 5.2
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
My YouTube Channel http//www.youtube.com/c/MiledRizk
in reply to: miledrizk
These settings were already there
miledrizk
Try resetting your User Settings by:
1- Close 3DS Max
2- Go to: C:\Users\YourUserName\AppData\Local\Autodesk\3dsMax\20xx - xxbit
3- Rename the folder called ENU to something else like ENU.Old
4- Restart Max
Note: AppData is a hidden folder, so you need to enable the option that shows hidden
Files and folder from the Control Panel
miledrizk@gmail.com
Sometimes an object's transform can be locked, look for an actual button with a lock on it at the bottom of your file window, if it's highlighted yellow that means its activated. you can easily have activated it without realizing because the shortcut for is is the spacebar, so try 'unlocking' it
