3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Named Selection Sets changing to random selections
1 REPLY 1
321 Views, 1 Reply
Hi all, quite new to 3DS Max and enjoying it so far but this is really frustrating me. I'm creating selection sets, but when I try to recall them they just come back as randomly selected polygons. This happened earlier today and I lost about 2 hours work. I started again and checked as I made them to see they were recalling correctly and all was fine. Saved it, closed it, came back and it's doing it again. Another 2 hours work gone.
As an example, here's the selection set I created as "windscreen". When I called it back during the same session it was fine
Then I've gone away and come back, and when I've tried to recall it again it's come back like this:
Same goes for the dozen or so other selection sets, all random, no pattern, all over the place. Am I saving them wrong? Is this some sort of error? It's absolutely infuriating!
Using 2017, Windows 10 (latest update).
1 REPLY 1
RGhost77
RGhost77
After make selection set are you add new polygons to object? Selection Sets stores index number of polygons. When you add a new polygon order of polygons can be changed but not in Selection Set.
So Selection Sets works good only in you don't add new polygons/vertexes/edges.
Royal Ghost | veda3d.com
