Except a few, my objects are seeming grey and when I change their color, only their edges' color are updating correctly. Why the surface colors are not updating?
My model is in the attachments, thank you so much.
Solved by miledrizk. Go to Solution.
Try saving it in Max 2018 so i can take a look at it
The explanation is simple,
All your objects have Physical Material applied to them, except those in the image below
Objects with no materials
In the material editor, choose an empty material slot, then use the eyedropper near the material's name
And click on an object in the scene, other than those in the image above, and you'll see the object's material
Showing up. Now you can edit it as you like.
All have a gray color except the black metal on the table's legs which is also a physical material but
With a black color
Pick material from objects using the Eyedropper
