3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
multiple cuts in object
3 REPLIES 3
pedrox1000
943 Views, 3 Replies
I need to perform a multiple cut to the object i attached. More specifically i need an edge every 50 cm in the x axis. Doing it with the slice plane its kinda of boring and in the end, the last part may not be very correct. Connecting edges does not work since this is a irregular ngon. Is there any script or something i can use for a task like this?
Thank you
3 REPLIES 3
10DSpace
in reply to: pedrox1000
@pedrox1000
Yes, try this script out.  It works for me.
http://www.scriptspot.com/3ds-max/scripts/slice-tool
pedrox1000
in reply to: 10DSpace
Nice ill try that 🙂 Thank you
pedrox1000
It works like a charm. Thank you!!
