3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
mesh disappearing on zoom
6 REPLIES 6
25107 Views, 6 Replies
Hi, I imported a mesh (fbx) and I have a problem with the object disappearing when I zoom in. It's as is there's a visibility clipping plane or something. Any ideas on how to change this?
Thanks, monks
6 REPLIES 6
Steve_Curley
Click the Viewport Label (e.g. Perspective) > Viewport Clipping. However, you shouldn't really need to alter that unless your objects are far too big, or small, with respect to the System (NOT Display) Units, so check that as well.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
in reply to: Steve_Curley
I tried changing the system units- up and down by factors of 10 but it didn't alter the behaviour. Looking at the mesh in object properties its dimensions are 25 x15 x17m. Sys units is set to metres. display units are set to metres. The models seems tiny though compare to ths grid size...I had Max set up to work with a terrain map previously, could it be this?
Steve_Curley
You can't just change the Units. If you make the units smaller then you also have to make the object larger otherwise the object is also smaller by the same factor. Starting with 25 Meters as an example, change the Units to cm (a factor of 100 smaller). Object is now 25cm. No difference in terms of scale. Make the object 100 times larger it will then be 2500cm which (unsurprisingly) is the same as 25 Meters. You can't do one without doing the other. Use the Rescale World Units utility (Command Panel > Utilities tab) to do it - do NOT use the Select and Scale tool.
Max 2016 (SP1/EXT1)
Thanks, that's worked. 🙂 Do I have to reset this back for future projects?
monks
Steve_Curley
You should set the System Units before anything else (in a new scene). This means knowing in advance (roughly) how big (and small) the largest (and smallest) dimensions will need to be. Depends on the scene as to which units you choose, but bear in mind that Max does not like large dimensions (hundreds of thousands) or very small dimensions (many decimal places) so choose your units carefully and make sure you model to that scale. So in that previous example, set the Units to cm first then create the object 2500cm long. Essentialy use "real world" measurements - 25M = 250 decimeters = 2500cm. You get the idea. You can "play" with the units to a degree, so if M would be too big (requiring decimal places) and cm too small (large dimensions) consider setting the Units to (effectively) Decimeters (1 unit = 10 cm) - a nice "middle ground" in some cases.
Max 2016 (SP1/EXT1)
Hi, thanks that fixed it!
monks
Technology Administrators
