Hi, I imported a mesh (fbx) and I have a problem with the object disappearing when I zoom in. It's as is there's a visibility clipping plane or something. Any ideas on how to change this?
Thanks, monks
I tried changing the system units- up and down by factors of 10 but it didn't alter the behaviour. Looking at the mesh in object properties its dimensions are 25 x15 x17m. Sys units is set to metres. display units are set to metres. The models seems tiny though compare to ths grid size...I had Max set up to work with a terrain map previously, could it be this?
Thanks, that's worked. 🙂 Do I have to reset this back for future projects?
monks
