3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
.MAX to .3ds file
6 REPLIES 6
21136 Views, 6 Replies
.MAX to .3ds file
Hello, can sombody tell how to convert a .max model to .3ds model?
i made a plane but i wanna make a .mdl from it. So i get the SDK's for makeing the mdl.
First the model must to go to .x (something with DirectX) then to mdl.
i can't convert my model to .x directly. i tried a plug-in but there was only a .dle file without saying where the .dle file must to go.
(Link to plugin)
can sombody help?
thanks
Info
- Autodesk 3ds MAX 2014
6 REPLIES 6
Steve_Curley
It tells you quite clearly on the page you linked what to do with the .dle.
Unzip and extract the .dle file, place in the 'Plugins' sub-directory under the main 3dsmax folder. Backup and remove any previous versions.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
in reply to: Steve_Curley
always fail to open
Plug in failed
So what to do?
Steve_Curley
It won't. There's no download for 2014, only for versions up to and including 2012. Plugins have to be recompiled with the correct compiler for each version of Max, they are not interchangeable.
Max 2016 (SP1/EXT1)
What to do then? Autodesk won't help me and here is too an dead end
Steve_Curley
You mean how to export an object as a .3ds file? Select the object, App Menu > Export > Export Selected. Change the Save as Type (lower drop-down list) to "3D Studio (*.3DS)", give it a name and click Save.
As for .x files, have you tried google? There's bound to be software out there for converting to/from .x files.
Max 2016 (SP1/EXT1)
Steve,
Is there a way convert .MAX to .iGES or .STEP?
Thank you,
Bryce
