Hello, can sombody tell how to convert a .max model to .3ds model?
i made a plane but i wanna make a .mdl from it. So i get the SDK's for makeing the mdl.
First the model must to go to .x (something with DirectX) then to mdl.
i can't convert my model to .x directly. i tried a plug-in but there was only a .dle file without saying where the .dle file must to go.
can sombody help?
thanks
Info
- Autodesk 3ds MAX 2014
Solved by Steve_Curley. Go to Solution.
It tells you quite clearly on the page you linked what to do with the .dle.
Unzip and extract the .dle file, place in the 'Plugins' sub-directory under the main 3dsmax folder. Backup and remove any previous versions.
