3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Low poly Models/Vray
1 REPLY 1
719 Views, 1 Reply
Does anyone know a good tutorial for changing a highpoly model to low poly one? And another question about vray is it used to only render objects as pictures or can i export the object with the vray material somehow? Sorry im new to this si trying to understand
Thank you alot
Thank you alot
Tags (1)
1 REPLY 1
Regarding your first question (High poly to Low Poly) You can Use (ProOptimizer) Modifier. for 2nd question V-Ray Has Proxy feature, whic you can export any models as a v-ray proxy by selecting the object and selecting V-ray mesh export. if you are using v-ray 3.6 they added another feature for saving v-ray scene as a file (.vrayscene).
