Hi folks
I have a beginner question (several similar questions around, but still I am unable to solve my issue).
This is my initial model (note the missing edge between the selected vertices):
In editable poly mode, I selected the two vertices and hit 'connect'. The result is the following:
The edge looks good, however the upper face turned black. Why is this happening? What can I do to fix this?
I also checked the normals and smoothing groups: They look good to me.
Thank you very much!
PS: The model is also attached
@Anonymous wrote:
Hi folks
Normals are off. Put an Normals modifier on top to force a recalculation.
