Hi
Thought I'd give a heads-up before making a bug report, in case anyone else has encountered it or knows of a workaround. I'm still using Max 2020 as 2021 is too slow. But I've noticed at random that I'll no longer be able to select some vertices on a model. It sometimes happens if I turn the Reference System to Local and then it's fine when I go back to View. For my current model, it's done it to my centred vertices. I did have a TurboSmooth modifier on earlier, so that might have done something. I'll try dragging and selecting and it selects nothing. So I tried exporting the model out to 2021 to see if the issue would show up there. Instead, nothing appears at all. No model. Just a small X and Y and a little square in the centre. It's like the model is invisible. 😕
![3dsmax_vQ1n6CipPp.png 3dsmax_vQ1n6CipPp.png](https://forums.autodesk.com/t5/image/serverpage/image-id/794261iB14CEEFA2DFFD295/image-size/large?v=v2&px=999)
![3dsmax_vJXxrJx1rd.png 3dsmax_vJXxrJx1rd.png](https://forums.autodesk.com/t5/image/serverpage/image-id/794262i66901E992A63A803/image-size/large?v=v2&px=999)
