Chris Medeck
This is late BUT, if you clone the object around its center axis 180 degrees (top to bottom) you can use the second one as a Snap Tool.
1) Select all bottom vertices of obj 1,
2) Scale along single (in this case vertical) axis to zero,
3) Move and snap the row of vertices, to the bottom vertices on Obj 2,
4) Delete obj 2.
Before Snapping you will want to right click your Snap Button and choose Snap to Vertices only!
