simple question: How do I FREEZE TRANSFORMATIONS in 3dsmax?
Found only an old video, but I haven't found that menu in 3dsMax 2020.
(https://www.youtube.com/watch?v=FYrZlFbAMD8)
p.s. I have Maya Navigation enabled (because I am mainly Maya user), maybe that's why it is missing the ALT+RMB menu??
Whenever we had a camera view set and didn't want to accidentally truck the camera, we'd use the Locks checkboxes found in the Heirarchy tab, Link Info button. Lock your Move, Rotate, and Scale in any or all axes.
Chris Medeck
Hi thanks,
but I mean something different: In order to export it to zBrush properly (for example) you need all transformations really zeroed to 000 for everything like scal, rotation, translation.
In Maya it’s called „freeze transformations“.
You must have a way in 3dsMax to export things properly to zBrush and similar applications.
If you leave high transformation values you get problems with scene scaling there.
You are looking for the Reset XForm. It is found in Utilities (wrench icon at upper right). If it isn't in your sets buttons, you'll have to configure it and add it in. Basically turn it on, and hit Reset Selected. Then go to the modify panel and collapse.
But...now that you know what you need. There's a better, easier way. In the menu at the top, Edit > Transform Toolbox. (Instead of Transform Type-In getting the F12 shortcut, I set it to the Transform Toolbox). Open up that toolbox, and click the R right next to Set Size. This will do a Reset XForm and collapse all at once.
Edit: And if you specifically need that Freeze Transform in the menu, it is Alt + Right Mouse Button. With 3ds Max, there's like 6 or so right click menus, when also using combinations of Alt, Ctrl, and Shift.
