How would I put caps on the top and bottom of the shape in the attached file?
Using 3ds Max 2015 on Windows 7 Pro.
thank you
Solved by miledrizk. Go to Solution.
sorry i don't have access to a higher version so i cannot view your model, if you have delete the end of your model go into the borders of the sub-object and then click on cap this will cap the end of your model
First you need to weld your vertices, since now your model is made of
4 elements, so go to Vertex subobject level, select all vertices, click on the square
setting button next to the Weld button and use a very low value like 0.001 and click Ok,
Now go to Border subobject level, use CTRL + A to select all borders(= two borders),
Right click and choose Cap. You can also find the Cap button on the Edit Borders rollout.
https://drive.google.com/file/d/1_hmEhfdpBsMvTZcjuTskdh7IOtfoHIYx/view?usp=sharing
Thank you. I couldn't figure out how to tie the vertices together.... it worked perfectly.
Thanks again for all your help.
Richard
