3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
How do i select all edges between two edges?
7 REPLIES 7
Message 1 of 8
2598 Views, 7 Replies
how do i select all of the edges between both of these edges so i wont need ot click each on of them?
thanks
7 REPLIES 7
Message 2 of 8
rendermaster
you need to manually select it, use crossing selection for multiple selection.
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
Message 3 of 8
in reply to: rendermaster
so there is no way to do this? i need to select the entire rind and then deselect the edges i dont want?
Message 4 of 8
rendermaster
before selecting those edges with window crossing selection, right click first on the object and select Ignore Backfacing so you can select only those that are in the front .
Message 5 of 8
i cant believe that such a basic thing is impossible...
Message 6 of 8
You can do this with 'Step loop' with any subobject, just not with Edge-Rings. Strange indeed.
Message 7 of 8
robw
Hey, I don't if this is what you mean, but I select my first edge, then holding CRTL double click the last edge. Max then selects all the ones in between. It works for loops or ring sections.
If that's what you meant  🙂
Message 8 of 8
atlaspej
You can do this by holding ctrl-shift and selecting an edge you want and hovering over the edges you wish to select and clicking on another edge to confirm.
