I am new to 3ds Max. I do not have the intention to use it more often, but I need it to create a few cross-sections. I got a working model from someone else, which works and he even made a simulation with it. I need it to make some crossections of the building, but I encountered a problem. I see a lot of squares around the objects, which make it impossible to see the things I actually need. I've got about 600 objects in the model, but for every object I also see a cube. This results view as you can see in the attachments.
I tried to repreduce the steps of this post: https://forums.autodesk.com/t5/3ds-max-forum/how-to-remove-white-boxes-around-object/m-p/7107917, but that did not solve the problem. Has someone encountered the same problem and solve it?
I use Windows 10 Home (16299) and 3ds MAX 2019, with the latest Vray plugin.
Many thanks in advance,
Remy
Hey Remy! Hope you start using Max more, not less 🙂
About your issue, hard to tell what's wrong. Those things you call "cubes" could be point helpers, could be selection brackets, could be mesh displayed as box, could be adaptive degradation turned on...
Can you share the file (even if partially) so we can better see what's your issue and maybe help you overcome it?
Cheers!
If you only care about the geometry objects I suggest you go to the Display panel,
Check all object types and leave the Geometry unchecked, this way you'll only see geometry
Objects in the scene.
right click on the object, go to object properties and untick show as box
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
