How do I remove the boxes that are around objects
- Mute
- Permalink
- Report
I am new to 3ds Max. I do not have the intention to use it more often, but I need it to create a few cross-sections. I got a working model from someone else, which works and he even made a simulation with it. I need it to make some crossections of the building, but I encountered a problem. I see a lot of squares around the objects, which make it impossible to see the things I actually need. I've got about 600 objects in the model, but for every object I also see a cube. This results view as you can see in the attachments.
I tried to repreduce the steps of this post: https://forums.autodesk.com/t5/3ds-max-forum/how-to-remove-white-boxes-around-object/m-p/7107917, but that did not solve the problem. Has someone encountered the same problem and solve it?
I use Windows 10 Home (16299) and 3ds MAX 2019, with the latest Vray plugin.
Many thanks in advance,
Remy
