I'm experimenting with 3d printing and wish to create a tube system based on this vase. Im completely new with 3ds max. What's the easiest way to simply bend the entire model 90 degrees?
The file can be found here:
Thanks.
You can use a Bend modifier.
You will have to play with settings to achieve exactly the result you want.
Check my attachment with an example.
