I need to be able to place some objects at specific position in Grid Coordinate system.
For instance , I want to place a box at 0,0,0 in a Grid Coordinate system...
Looks quite simple ... BUT after 1h searching arround looks like there is no solution for that ...
the transform Type In is stack on 'Absolute : World' no way to go for 'Absolute : Grid' ... grumpf
tank you for help 🙂
Hello. Please watch the video at this link: http://screencast.com/t/dwPyhKMwSCc I believe it will help you. There is no audio as I am having trouble with my speaker/mic. You can also view the video thru the subscription center via case number 09528342.
Thank you for this answer,
As far as you work on objects gizmo it's ok ; but if you go in a poly object vertex for instance it doesn't work, the absolute go back to World and only the offset stay on the grid !!
any idea on that ?
