3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Grid Coordinate System
3 REPLIES 3
david.desbuisson
465 Views, 3 Replies
I need to be able to place some objects at specific position in Grid Coordinate system.
For instance , I want to place a box at 0,0,0 in a Grid Coordinate system...
Looks quite simple ... BUT after 1h searching arround looks like there is no solution for that ...
the transform Type In is stack on 'Absolute : World' no way to go for 'Absolute : Grid' ... grumpf
tank you for help 🙂
Tags (1)
3 REPLIES 3
Hello.  Please watch the video at this link: http://screencast.com/t/dwPyhKMwSCc  I believe it will help you.  There is no audio as I am having trouble with my speaker/mic.  You can also view the video thru the subscription center via case number 09528342.
Thank you for this answer,
As far as you work on objects gizmo it's ok ; but if you go in a poly object vertex for instance it doesn't work, the absolute go back to World and only the offset stay on the grid !!
any idea on that ?
can you provide me with a video of what you are seeing?
