3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Editable Poly issue when rendering - "Edges" are showing.
4 REPLIES 4
672 Views, 4 Replies
Hello!
What is causing my mallet to render like that?
When I add a TurboSmooth Modifier, it smooths the metal rings to bumpsrender1.jpg
4 REPLIES 4
You need to set up different smoothing groups on your model. Each area that should be smoothed together should be assigned their own group. If you want a hard line make sure the opposing faces are in a different group.
For example:
Go into the face selection of the object and assign the following smoothing groups.
  • Assign the hammer head group 1
  • Assign the top and bottom of each ring group 2
  • Assign the sides of the rings Group 3
Then enable the smooth by groups option in the TurboSmooth modifier.
hagen.deloss
Hi @Anonymous
I would add to what @Anonymous suggested and say that you could also build the object "to smooth", which pretty much means the model is built to be displayed in a high poly form.
The chamfer tool will help you get the result you want. you will want to make sure each edge loop is close to the corner you want to make sharper.
Here is an image explaining the concept a little further.
I hope this helps!
Please select the Accept as Solution button if a post solves your issue or answers your question.
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
hagen.deloss
@Anonymous
I wanted to check back and see if a post helped you with your problem. It would be super helpful if you could add a post with how you decide to proceed, and your results. That way other Community members can benefit from your process 😄
Hagen Deloss
in reply to: hagen.deloss
Thank you so much for the visual support.
This solved my issue - thank you!
