Hi guys,
I'm a beginner in 3ds Max, so if my question is stupid i'm really sorry!
i have a problem with edge extrusion, as you can see in the picture 2 the extrusion looks like soft, but i don't wont it in that way, what can i do to fix that problem?
(If already exist a forum with this discussion please let me know, because i didn't found it).photo 1
photo 2
Solved by miledrizk. Go to Solution.
Well not sure if i understood, but do you mean the two small extrusions you did they
Feel like they don't have an edge between them?
Well if that so i guess you're thinking like that because you're in the Xray display mode,
Press ALT+X again and check it again. Maybe a quick render will give you better idea.
Now if they are really soft, select those problematic Polygons, go to Polygons: Smoothing Groups rollout,
Experiment with low values for Auto Smooth and click the Auto Smooth button. Maybe you can start with
Values like 15 or 20 and see what happens.
hi dear friend please show us final result picture which you want to get so when can help you correctly or try to remove unwanted edges or vertexes.
thank you
