3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Easy way to make floor?
7 REPLIES 7
Message 1 of 8
3362 Views, 7 Replies
In the attached IMAGE, in the colored zone (GREEN) you can see where i want to make the floor.
There is a simple method to make this type of floor?
7 REPLIES 7
Message 2 of 8
rendermaster
just use spline then extrude it
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
Message 3 of 8
in reply to: rendermaster
Hi, there is a problem when i select the spline (RECTANGLE 1) and (convert to editable spline)
automatically includes the spline (RECTANGLE 2)
so when i use (Extrude) the final result is what you can see in the attached IMAGE
How to fix this problem?
Message 4 of 8
irishman_team_kilber
you are using 2 on one floor why not create the first floor by using a spline and then click the retangle select the spline outline then click on attach this will add the extude this will cut a hole in the floor then add a plane the name size as the hole.
i only use this spline and retangle attach extude method  if i want to create a swimming pool or a hole in the hole where i am going to put the stairs
this is not the best way of doing it
Message 5 of 8
bob.bernstein
what is the colored zone?  Is that a polygon?  If so, just extrude it.
Or, just create a new spline by snapping to the appropriate edges of the walls.  and then extrude.
Message 6 of 8
in reply to: bob.bernstein
I want to create a hole where the (RECTANGLE 2) is located, look at the attached image.
What is the fastest method?
Message 7 of 8
my post told you how to do it, create 3 2d retangles, make third one a copy and move it upwards and convert one to a edit spline then the two together attach it, now add an extude modifer to them now you have a hole in move the third one down so it covers the hole and put another extude on that one. you can now texture it
Message 8 of 8
in reply to: irishman_team_kilber
ok thanks 😄
