I am a beginner in 3 dmax and I want to ask
if there is a cable tray suspended on the ceiling and firefighting pumps
does the 3d max has the ability to draw them ( as there is no false ceiling in the room and I want to draw them ) or I have to draw it by Revit ?
Solved by leeminardi. Go to Solution.
Might need a photo or screenshot to be better able to know which method would be the best for what you want to achieve.
I want to draw a ceiling like what in the picture , can I draw it by 3dmax ?
You can easily create the cable trays by adding a sweep modifier to a line representing the path of the tray. Use the Channel Built in section and rotate if necessary. Use a tiled opacity map to model the hole pattern.
