Hi, During rendering I am getting double image - like on the screen. Does anyone know how to sort it ? Thank You in advance!
Solved by ads_czechoj. Go to Solution.
Solved by rendermaster. Go to Solution.
Solved by jon.bell. Go to Solution.
It looks as if you have a stereo camera (that is, true "3D") set up in V-Ray, so it's rendering left-eye/right-eye views.
Can you check your Camera settings and make sure this isn't on? Thanks!
check if you have vray dome camera in the scene, delete it
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
I found one solved thread with the same issue. Maybe in your case this will work as well:
https://forums.autodesk.com/t5/3ds-max-forum/double-render-frame-with-v-ray/td-p/9170878
