3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Door not cutting through wall
9 REPLIES 9
Message 1 of 10
manibhleria14
6168 Views, 9 Replies
Hi
I encountered a weird problem this morning when a couple of my door objects did not cut through the wall. After searching the internet, i thought it would pay to ask it in here than wasting any more time.
Simple question would be why is it doing this? What am i doing wrong?
I have created a few more doors in the same scene file, same type of door, created the same way, moved around to fit in the right position, they are all good but not the ones in question.
Photo and model attached.
9 REPLIES 9
Message 2 of 10
miledrizk
in reply to: manibhleria14
The Door object only works with the Wall object,
The Wall object exists in the: Create Panel - AEC Extended - Wall,
Obviously, i'm assuming you did all the right steps, you used it with an ordinary geometry, this is why it failed
Note: i have 3DS Max 2015 so i couldn't open your file,
In case i was wrong in my assumption, try saving the file in Max 2015, and i'll check it for you.
Note: In case you really used the Wall object, for the Door object to cut through, you need to activate the Edge/Segment snapping,
And make sure, while dragging the mouse to create the width and the depth, that it's snapping to the edges.
miledrizk@gmail.com
3DS Max 2021, V-Ray 5.2
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
My YouTube Channel http//www.youtube.com/c/MiledRizk
Message 3 of 10
Hello, try watching this screencast
Message 4 of 10
manibhleria14
in reply to: miledrizk
Hi Miled
I do not know what went wrong. I was using the right way i think. The object is definitely a wall object. I might be snapping it to something else at the time of creation.
I have now been able to get it to work.
The solution i think is that it need to be snapped to both the edge of wall at the time of creation. It could be moved around afterwards and that does not affect the anchoring to wall.
Message 5 of 10
miledrizk
It's true that you need to get it right from the beginning, by snapping at both wall edges,
But, after that, if for some reason your door shifted away from the wall, you can still move it back and the
Wall's opening will be restored. You don't need to create a new one.
miledrizk@gmail.com
Message 6 of 10
lemoinemarc
For people who might stumble on this subject:
if for no reason your doors or windows don't cut trought your wall, you should check the hierarchy of your objects..your wall should control all your AEC for them to interac with it.
Message 7 of 10
in reply to: lemoinemarc
Not sure what you mean the walls should control the doors...I have walls and doors on seperate layers and most of teh doors are cutting correctly but a few are not. In my hiearchy the wall layer is above the door layer
Message 8 of 10
lemoinemarc
Hi! By control I meant the hierachy (I didnt know how to say it with 1 word). As for the reason you have some doors not cutting through, is the depth higher than the width of the wall? Do they have the same orientation?(0°-90°)
Message 9 of 10
Thanks for you reply..I figured it out
Message 10 of 10
s2201001748
HI .
In 3ds max 2023 I can't cutting the door through the wall , I did all thing right , I drew a wall and then chosen snapping tool -edge then drew the door but it isn't cutting ?
I don't know why ??
