3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Connecting splines to create a shape
2 REPLIES 2
sburkeW2VGV
961 Views, 2 Replies
Hey guys. Another noob question. How to connect these splines to create a surface between all of the shapes? I want to make a bathtub this way. Cheers guys!
2 REPLIES 2
in reply to: sburkeW2VGV
there is lots you can do to build lines into sculpted object by adding a surface modifier on top of a crosssection modifier.
I kept a complete stack of modifiers where I:
drew 2 rectangles and 2 elipses,   In each form (rec, elip) i "Attach" each to its similar other, then add Crosssection and Surface.  I then used a Boolean Compound Object to take that square outer solid and "Subtract" the eliptical inner object.  I probably could have used Pro Cutter or ProBoolean but I'm less experienced with these.
sburkeW2VGV
Thanks man! It was more simple than i thought. I used crosssection, and i got exactly what i wanted.
