Cant create datasmith file
ahmet.sait08
ahmet.sait08
I want to export my scene to unreal engine using datasmith but when i click to export ıt only creates assest folder but no udatasmith file how can ı fix this please help
Replies (7)
RobH2
Can you provide a bit more info? What version of Max, what version of Datasmith, a few screenshots of your workflow, etc.? That will help diagnose the issue.
Have you uninstalled datasmith, rebboted, reinstalled and then tried again? That might correct some corruption that could have ocurred.
What do you see in the 'Messages' panel when you export? That might give you some insight.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
ahmet.sait08
Thank you for the reply 🙂 My 3dsmax version is 2025 unreal engine 5.5.1 and ım using 5.5 exporter for datasmith
ıve tried uninstall reboot and install method but its not working for me. Btw ı encounter this issue before and randomly ı delete a car in my scene and it worked before but this time i tried to delete most of my object still not working
here is my work and messages panel:
RobH2
I wonder if there are some errors in some of the other objects that are causing Datasmith to fail. You mentioned a car caused a failure. Have you tired to export the model as FBX just to see if it exports OK with no errors? I know this is not what you want to do, but it's just a test to see what works and what doesn't work. If a normal FBX fails then it's probably not Datasmith's fault. I'm just trying to find ways to start diagnosing.
I use Datasmith all the time and have very few problems with it. I have all of the same versions of Max, UE, and the exporter as you. I don't know if you can do this but if you can share your file I'll try to export it. And, if I do get it to export with Datasmith, I'll return the Datasmith file to you. That might get you going for now until you figure out the problem.
Rob Holmes
ahmet.sait08
Can you send me your mail adress so ı can send you the files? By the way ı dont see any issues exporting as fbx
RobH2
Working on this in PM. Will report back if we figure out what caused the issue or what a solution is.
Rob Holmes
RobH2
I see you sent me a PM link but it's not functioning. Until you send a new one I played with a complex file to see what Datasmith would do. This is a scene I bought 9-years ago. I wanted to throw in the possibility of old code causing issues to see if that was something to worry about as well.
As you can see, the Datasmith export and import into UE worked really well. I had to spend about 45-minutes fixing lights but didn't touch anything else. I had to make a few surfaces 'Two-Sided' as is frequently the case. But in just a short time, the result is pretty close.
So there must be something on your machine that's causing the issue. What are your machine specs? How much RAM? Laptop or desktop? Video card? Maybe you are running out of RAM and Datasmight can't finish writing the file. I don't even know if that's a possible culprit, but I'm just trying to diagnose. Once I see your file I may have more thoughts but for now I think something on your machine is causing it. I don't think it's a bug in Max or Datasmith. We just have to figure out what on your machine is causing the export to fail.
Rob Holmes
RobH2
I received your file. When I tried to export the whole thing, all 3.6Million polys, I didn't get the *.datasmith file. Since it's a large file file I assumed it would take awhile. After 10-minutes and no file I Googled for 'Datasmith file size limit.' I found this link: Datasmith File Size Limits
While it technically doesn't have one, there is the chance that a huge file like yours just needs to be broken up. So I tried that and it works perfectly. I exported each of your major layers out separately: Default, A-Blok, B-Blok, etc. It worked pretty well. C-Blok only exported if I did it in two parts, 1)the building and 2)'lamp wall' parts that are offset to the side of the building. But, the lightwall part did not export. You might have to play around with that a bit to see why not.
So when Datasmith fails, just break you model up in an intelligent way and it will likely work for you. Breaking it up is a good idea anyway for organization.
I don't know if the textures are intact. You use Corona and you didn't send me the texture files anyway. But go try again and break it up. I will probably work for you.
As to the stuttering, well, it's a huge file. My processor is about the same speed as yours and it took 5-minutes just to load the file. It's pretty stuttery in Max. In UE though, it is pretty smooth once you get it in there. I'll upload the Datasmith files (in a PM) I made and you can try them. I'll also upload a video showing the model in UE 5.5. Its looks really good to be honest.
One last thing. I see you have 32GB Ram. I have your file open in Max and I'm using 53GB of my 128GB Ram. If you are getting slow performance it's probably because you've run out of Ram and the machine is paging memory out to a temp file. That's magnitudes slower than the Ram. I generally tell people that to have a resonable experience with Max you need at least 64GB of ram. That's probably why you are seeing poor performance. Even with my larger Ram, I still only get 2-fps in the viewport. It's just a big file.
Rob Holmes
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
