hello everyone ...
i can't select any objects when i am in prespictev viewport only select from workspace explorer
note:selection lock toggle disabled , selection work normally in the other viewports
thanx in advance
Is it for a particular Max doc or is it common in all of the Max files you have. Can you post a GIF or a screenshot of your viewport?
Strange! but maybe something messed up your User Settings folder,
I suggest you reset it by:
1- Closing 3DS max
2- Go to: C:\Users\YourUserName\AppData\Local\Autodesk\3dsMax\20xx - xxbit
And rename the folder called ENU to something else like ENU.old and restart Max.
Note: AppData is a hidden folder so you need to enable show hidden files and folders from
The Control Panel
