Hi @Anonymous
If you have correctly assigned the material to the plane and enabled "Show Shaded Material in Viewport", then:
1. make sure that "Material Color" is selected in the Display Color section of the Display Rollout.
2. Make sure that you are not in "see through Mode" (right click on the selected plane, select "Object Properties" and then Uncheck "See Through" if it is checked.
Hope this helps.
The image you uploaded is a bit fuzzy, but it appears that you can see through the object to the grid behind it which suggests it may be in see through mode.
@Anonymous
I figured it out. I used jpg's instead and it worked.
What type of image format were you originally using?
Is there a maximum size bitmap that 3ds max can open? or it can't open 24 bit images?
I am sure there is a technical limit for any 3D software and computer hardware, but Max can handle large images like 8K, 16K in addition to the more typical 2K, 4K & 8K sizes used in graphics pipelines. Regarding 24 bit images, Max handles these without any problem. I use them daily.
